Author Topic: Question and advice  (Read 3790 times)
Offline -Craig-
Question and advice
« on: 10 March 2013, 15:35 »
Ok well firstly hi everyone, I am new here and pretty impressed with some of the projects etc. I am a Ford tech myself and this is my first VW and its a TURBO!  :laugh:
I bought the car last weekend and love it, however, when I got it back it felt like it had a very slight hesitation, I was advised from the guys at work to clean the throttle body out which I done, will I need to get the values reset on VAGcom?
Also, it has now developed what I beleive to me a missfire, I have changed the plugs with no availl. Will I need to get this plugged in and see what (if any) cylinder is missfiring? I am going to unplug the MAP sensor and see if this does anything. If a coil is down, would it cause the car to boost below 5psi as thats what it does at the moment?
All help appreciated, thanks!
Offline -Craig-
Re: Question and advice
« Reply #1 on: 10 March 2013, 17:03 »
Just been out to the car, dis connected one coil pack at a time, engine still run ok. Unplugged the MAP sensor on the air intake and car run ok.
I dont think its boosting 100% at all as on my gauge it dosnt even get to 5psi, any suggestions?
Offline barrym381
« Reply #2 on: 10 March 2013, 17:36 »
what year is your car an have you scanned it to see if any codes come up  :smiley:
Offline -Craig-
« Reply #3 on: 10 March 2013, 18:28 »
Car is a 2000 1.8T AGU. I dont have VAG com and my work code reader dosnt comunicate with it, its only a basic one.
Offline barrym381
« Reply #4 on: 10 March 2013, 19:16 »
buy a cheap1 mate they are only basic but gives you an idea of were to start  :smiley:
Offline -Craig-
« Reply #5 on: 10 March 2013, 19:18 »
Any suggestions on which one? Thanks
Offline Rhyso
« Reply #6 on: 10 March 2013, 19:25 »
Did you disconnect the MAF or the Ignition Amplifier?
The latter is on the back of the airbox; they usually play up on the AGU
Offline -Craig-
« Reply #7 on: 10 March 2013, 22:21 »
I unplugged the MAF I beleive. I have a Carbonio filter system so In pretty sure thats the maf? Whats the ignition amplifier? Thanks
Offline Rhyso
« Reply #8 on: 10 March 2013, 22:35 »
If you don't have a standard airbox then the ignition amplifier will be tucked away somewhere. Its a small square box
Offline -Craig-
« Reply #9 on: 11 March 2013, 18:45 »
Just had a play around with the car, bought a Forge Diverter valve, fault still there! Should the car be pulling a vac all the time?
Is the Ignition Ampilifier the plug attached to the bulkhead which runs along the plastic trunking?
