Author Topic: Engine made a ticking noise on cold start  (Read 2565 times)
Offline GOLF-MK3-GTI
« on: 10 March 2013, 11:44 »
Started car up today 8V GTI in morning, heard a ticking noise from engine, so I popped up the hood. Don't Know where it was coming from, rev'd it to 2,500 rpm gradually and it got louder, switched it off to check oil, it was full. Started it again and it disappeared, then rev'd it a little again. It came back then disappeared.
Took it up the toad, and it's been fine after that. Waht could it have been?
I think, either oil pump, or air-con, it was coming from thereabouts.
Re: Engine made a ticking noise on cold start
« Reply #1 on: 10 March 2013, 11:45 »
Excuse my spelling, crappy Iphone
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 10 March 2013, 13:13 »
I had a simular problem it sounded like the injectors but you cant hear them inside the car. So started it back up and had a listen turned out to be the 1st spark plug worked its way loose :shocked:
Lucky it didnt shoot out. They all got loose lol
So have a listen to the sparkies.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline itavaltalainen
« Reply #3 on: 10 March 2013, 13:25 »
has it been standing for a while?
maybe hydraulic valve followers have run dry... should go away after at most a minute (< 30 seconds if you use 5w40 or 0w40 oil) but then not come back
but worth also checking sparks as said....
other than that you take fan belts off (both) and run for a short while and listen if the noise goes.... could be a loose pulley?
if it's still there take the top cam belt cover off (put the other two belts back on) and check if it comes from the tensioner, but tbh they don't normally tick, rather make a grindign noise...
« Reply #4 on: 10 March 2013, 13:47 »
Thanks for the replies, I've been driven it and keeping an hear open to hear any funny sounds, but it's been ok, it was only for the first 1 minute or so. Will keep a tab on over the next few days.
Offline spudboy6
  • Just like a golf ......
« Reply #5 on: 10 March 2013, 15:49 »
May have a slight manifold exhaust blow and the hot air valve flap from the airbox to exhaust magnifies the sound and after say 30secs the valve shuts and the nose goes ?
Gavv8
« Reply #6 on: 10 March 2013, 21:03 »
Mine does it when its very cold and i do use 5w/40 synthetic, i just put it down to mileage and thin oil.
Gavv8
« Reply #7 on: 10 March 2013, 21:13 »
Bit strong for a family show....... :shocked:
« Reply #8 on: 10 March 2013, 22:17 »
I use 10W/40 and it's never done this before. It was very suprising tbh. I'm just gonna wait till it does it again. So I can check what is causing this.
« Reply #9 on: 11 March 2013, 10:09 »
Started the car today morning, and didn't hear the noise. sounded sweet  :grin:
