Author Topic: front wishbones  (Read 1035 times)
Offline danmusic24
front wishbones
« on: 09 March 2013, 14:07 »
need to replace my wishbones,is it straight forward job or apain in the arse
mk3 16v?
Offline spudboy6
  • Just like a golf ......
Re: front wishbones
« Reply #1 on: 09 March 2013, 17:39 »
Fairly simple job if your doing just arms is easier and just undoing the three ball joint nuts off the arm and leaving the ball joint in the hub .  If changing everything including balljoint its slightly trickier as will need a chisel to wedge in the hub to remove the ball joint
Offline AGGGTi
Re: front wishbones
« Reply #2 on: 09 March 2013, 19:51 »
Balljoints are abit different on a 5 stud (16v), tapered fit with a nut on top. Bit awkward to seperate, but a sharp blow with a hammer or use a balljoint splitter. But as above only required if changing balljoints  :smiley:
