Author Topic: Hunting, spluttering, cutting out :/  (Read 4026 times)
Offline search
Re: Hunting, spluttering, cutting out :/
« Reply #10 on: 10 March 2013, 19:48 »
Thanks, I cleaned them with a bit of carb cleaner, but it's free I will clean them again lol, I'm sure it's just an adjust issue. I'll report back ;)
idle screw just needs turning any way to make idle where you want it. mixing screw tighten it all the way (slowly so you don't over tighten it) then back out 1 and a half times. but i wouldn't mess with the mixing screw to much.
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline JC
  • Back in the North.
« Reply #11 on: 10 March 2013, 19:55 »
a 1.3 carb will not be the same a 1.8 gti digi  :lipsrsealed:
please be careful when giving advice that might be mis-leading.
analogue_rogue
« Reply #12 on: 10 March 2013, 21:14 »
woah sorry I misread it as an injection model.
If its a carb model check all jets for contaminates and check float height also check needle valve for correct seating.
don't touch the mixture screw without a gas analyser. its not worth the hassle.
Adjust idle to achieve 800 +/- 50
(I think that's the right idle but I stand to be corrected. either way its not a bad base level to start from.
Offline JC
« Reply #13 on: 10 March 2013, 21:17 »
The advice comment wasn't meant for you :whistle:
Offline ians
« Reply #14 on: 11 March 2013, 20:33 »
Thanks chuffed  :grin: I did get a bit confused there, have been out to sort it today, as it snowing :)
