Author Topic: which fuse/relay is for the rear wiper jet.  (Read 1135 times)
Offline Jasikasisback
« on: 09 March 2013, 00:19 »
rear wiper jet not working...is there a fuse/relay dedicated to this? can't seem to find it on the fuse diagram..:(. front jets work fine and back one is not blocked....:(
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: which fuse/relay is for the rear wiper jet.
« Reply #1 on: 09 March 2013, 05:47 »
Its blocked mate as the pump works off the same relay/fuse, only the wipers are different.
Try a pin in the hole of the rear window jet  :smiley:
Offline WeekendMechanic
  • Golf MK3 GTD
« Reply #2 on: 09 March 2013, 09:11 »
Yep uses the same relay in fact it uses the same motor as well, just in revers.
« Reply #3 on: 09 March 2013, 17:06 »
itook the gearshift cover off and found the bulb but it looks ok. no idea on how to remove it though i lifted it up, but doesn't come out. looks like it is attached? to some metal holder...
which fuse or relay is this on as not in haynes manual. i would swap them to see if that helps. oh and what kind of bulb is this and where can i buy one??
could the same fuse/relay be for the green light around the cigarette lighter?
happy days are here again  :(
« Last Edit: 09 March 2013, 19:06 by Jasikasisback »
