« Reply #8 on: 08 March 2013, 16:21 »
Just double checked all same as walkthrough. Also both front fans run on when switch car on too.......
So im left with dv top pipe T pieced to the FPR line.
The n249 wired up but nothing else plumbed in.
The other valve 1 pipe goes to the 1 way valve in the motor← side then too inlet manifol
Other pipe goes to the small pipe down right side engine/manifold
Just given it a big drive.
Plus point
Car boosts smooth to about 12-14psi
And has no spiking. And holds boost and slowly tails off as should. Picks up and just seems better BUT
Fans are running non stop both of em
Dumo valve defo sounds different/louder maybe
« Last Edit: 08 March 2013, 18:04 by davemk4 »
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
