Author Topic: engine fires then dies  (Read 1547 times)
Offline gary_e
« on: 08 March 2013, 00:39 »
I have a 97 Mk3 Golf
Due to my daughter having her handbag stolen :mad: along my only key I needed to remove the ignition barrel to take to the locksmiths. This included disconnecting the battery.
Job done I turned the engine over and it started over first time but died immediately. I tried a few more times but no matter how much I pumped the gas pedal the engine always dies as quick as it fired up.
Any help would be appreciated
Thank you
Offline Abf83
  • Mk3 16v Alpine White
Re: engine fires then dies
« Reply #1 on: 08 March 2013, 00:48 »
Sounds like an immobilser problem.
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 08 March 2013, 08:08 »
Your missing the chip thats inside your key. You could get one programed but they will need to see the old chip or read it before hand
Doh :rolleyes:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #3 on: 08 March 2013, 09:02 »
I have the chip coding for mine, have a good rummage through your handbook/wallet, might be in there if your lucky  :huh:
Offline gary_e
« Reply #4 on: 08 March 2013, 09:56 »
Oh - I did not think it had a key based immobiliser. It does have a separate immobiliser where I have to touch a button with a special fob.
An immobiliser stops the engine from stating at all doesn't it?
any help appreciated
thanks
Offline gary_e
« Reply #5 on: 08 March 2013, 10:25 »
Spot on - just been confirmed that it is the immobiliser
didn't even know I had one!!!
Thanks all
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 08 March 2013, 19:30 »
and for reference, the car will start but run for a second or two if the keys missing its chip
Offline carpetviper
« Reply #7 on: 08 March 2013, 22:45 »
Not much help to you but there's a shop near me (Sheffield) that can cut and programme keys from the ecu works out at a out £50 a key.
I know this had to have 2 done when the dog completely chewed mine up.
Offline Dogbot
« Reply #8 on: 09 March 2013, 13:23 »
If its a 16v abf I have a spare ecu, immob box and transponder chip that I would be willing to part with...
