Author Topic: engine starts then immediately dies after changing ignition barrel  (Read 2197 times)
Offline gary_e
I have a 97 Mk3 Golf
Due to my daughter having her handbag stolen :mad: along my only key I needed to remove the ignition barrel to take to the locksmiths. This included disconnecting the battery.
Job done I turned the engine over and it started over first time but died immediately. I tried a few more times but no matter how much I pumped the gas pedal the engine always dies as quick as it fired up.
Any help would be appreciated
Thank you
Offline barrym381
sounds like the immobiliser  :smiley:
Offline gary_e
Oh - I did not think it had a key based immobiliser. It does have a separate immobiliser where I have to touch a button with a special fob.
An immobiliser stops the engine from stating at all doesn't it?
any help appreciated
thanks
Offline barrym381
thanks
on our mk4 it will start then cut right back out  :smiley: an the key should have a chip in it
Offline weazgti
On the mk3 the transponder ring for immobiliser is on the ignition barrel with a chip in the key. Starts then dies instantly I'd it's not working
Offline dom
  • Back in a Mk4
^^ This.
