Author Topic: Double boost?  (Read 1091 times)
Offline Nino
Double boost?
« on: 07 March 2013, 14:53 »
Gunna scan her later and I suspect I still go that stupid 17005 thingy but the last day or two I have noticed that if I floor it abit she boosts up to about 8-10 psi, drops to 5ish then goes goes back up then hold steady at 5-6?
I have had that error code for a year and changed many things but she's never "double boosted" before. Any ideas?
Current - MK6 GTi Edition 35
Offline Dalo Harkin
Re: Double boost?
« Reply #1 on: 07 March 2013, 22:11 »
Yeah weird one that, boost leak maybe or N75 buggered
Offline Nino
Re: Double boost?
« Reply #2 on: 07 March 2013, 22:48 »
Would a damaged N75 or damaged N249 cause this?
Offline Scott D
Re: Double boost?
« Reply #3 on: 08 March 2013, 00:14 »
duff N75 could cause erratic boosting or MAF sensor and not show up any fault codes
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Nino
Re: Double boost?
« Reply #4 on: 08 March 2013, 00:18 »
They expensive? And hard to replace I know my maf is ok :)
Offline Scott D
Re: Double boost?
« Reply #5 on: 08 March 2013, 00:21 »
£40 for a N75 from the dealers and a five minute job to replace
Offline DubAndDubber
Re: Double boost?
« Reply #6 on: 08 March 2013, 00:50 »
I thought 17705 was a bug in the standard ecu?
Mk5 Golf Gti 06'
Offline Chris.
Re: Double boost?
« Reply #7 on: 09 March 2013, 19:42 »
It is.
Click For Build Thread
Offline Nino
Re: Double boost?
« Reply #8 on: 09 March 2013, 23:13 »
Maybe I just got that bug then  :huh:
