Author Topic: Problems with 3" exhaust system.  (Read 3277 times)
Benny.banks
« on: 06 March 2013, 23:01 »
Can someone tell me what hole the lambda sensor is meant to be in on the AGU 1.8T my friend has been to have his exhaust fitted and they've done a really poor job.
No they didn't do a poor job. just the exhaust is that badly designed no wonder its only £240....Stevie wonder could of done a better job.
« Last Edit: 08 March 2013, 16:44 by Benny.banks »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: lambda sensor position on AGU
« Reply #1 on: 07 March 2013, 09:54 »
Email replied to mate
Benny.banks
« Reply #2 on: 07 March 2013, 11:10 »
Cheers wazzer, no way he's been driving round with it in the after cat hole, what would this cause?
We don't know who it is tbh, my friend has phoned the company who fitted his 3" system and they told him they replaced the sensor in the same hole as his previous exhaust system.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 07 March 2013, 12:24 »
We'll it probably won't make that much difference now with the decat but it wouldn't have been ideal before...
Benny.banks
« Reply #4 on: 08 March 2013, 16:42 »
Does anyone else's 3" exhaust system only have 1 lambda sensor hole? as my mates does and its hitting the heat shielding. This can't be right.
This 3" exhaust is the worst why did my mate sell his Milltek :angry: .....blowing, rattles, only 1 lambda sensor hole, lambda sensors not fitting, clip's snapping, stupidly loud. I was laughing at him because he's just wasted £240
Offline dstv
Re: Problems with 3" exhaust system.
« Reply #5 on: 08 March 2013, 18:58 »
I have not checked mine for the sensors but mine went on no problems.. and is stil problem free ??
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline mar_k
« Reply #6 on: 08 March 2013, 19:15 »
The clips are cack, yes!
There was 2 lambda holes in the system I fitted,
The rear lambda was awkward but has now been sorted with a 90deg lambda adaptor.
It can rattle if its not fitted properly, usually with the crappy clips that are supplied.
Needs to be adjusted so it doesn't knock on the rear beam.
This exhaust is very good quality and does get quieter with time.
If your mates exhaust is blowing, it hasn't been fitted properly.
Benny.banks
« Reply #7 on: 08 March 2013, 19:19 »
What's this 90 degree lambda adapter you speak of? Think your my new best friend. (if it works of course)
New mikalor clips ordered, silicone exhaust paste ordered. It doesn't bang over the rear beam. I think its the heat shield hitting the back box.
There is only 1 lambda sensor on an AGU would a 90 degree lambda adapter cause running issues?
« Last Edit: 08 March 2013, 19:29 by Benny.banks »
Offline xtetx
« Reply #8 on: 09 March 2013, 15:29 »
Mines got 2 holes man! Also rattles a tiny bit but I just need to stop the back box moving slightly and it is fine :)
Offline mar_k
« Reply #9 on: 09 March 2013, 17:25 »
I don't really rate Mikalor clamps as they allow the exhaust to twist lose after time.
We used large U clamps on the exhaust, apart from the rear one over the rear beam as its really tight in there.
Here is the adaptor, the one we bought was a lot cheaper though.
http://www.ebay.co.uk/itm/Lambda-Spacer-o2-Sensor-Extender-ANGLE-ADJUSTABLE-Exhaust-Decat-90-degree-/221189060350?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item337fe536fe
