Author Topic: Rear door handle not opening! Need help  (Read 664 times)
Offline corf
« on: 06 March 2013, 07:04 »
My rear passenger side door handle has stopped working from the outside, but it still works from the inside
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Rear door handle not opening! Need help
« Reply #1 on: 06 March 2013, 09:09 »
I got a similar issue with my drivers door. Does yours lock with the rest of the car?
Mine only locks by having to push the button down so I have to clime across the passenger side to open it and lock it. Mine is the actuator which I need to replace when the weather gets better as I need to strip the door.
Could also be the lock module itself though have a search there are tons of threads about the door locks they seem to be a big problem!
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
