Author Topic: discs size  (Read 1790 times)
Offline coolio
discs size
« on: 06 March 2013, 00:53 »
can anyone tell me does GTI AND VR6 uase the same size brake discs ?
Offline sharki786
  • GOT BOOST??
Re: discs size
« Reply #1 on: 06 March 2013, 07:06 »
Depends what year. As they switched over to 288mm
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline boneybradley
  • Back in a Mk3...
Re: discs size
« Reply #2 on: 06 March 2013, 08:45 »
Gti upto early 95 used 280mm
all VR6 should be 288mm
Offline coolio
Re: discs size
« Reply #3 on: 06 March 2013, 09:20 »
how bout the running gears then if the GTI is 96 model 5 studs  does it have Same running gear as VR6 (rear axle,front wishbones ,hubs ,brakes,driveshafts,subframe,crossmember etc)
Re: discs size
« Reply #4 on: 06 March 2013, 10:56 »
Yes as all GTI's and VR's used the plus susp set up however spring rates on a VR are different due to engine weight.
  • Back in a Mk3...
Re: discs size
« Reply #5 on: 06 March 2013, 10:58 »
yes all the same (the year dosen't even matter, the only difference in gti/vr6 is the 280/288 front brakes as listed)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: discs size
« Reply #6 on: 06 March 2013, 11:49 »
Early Vr also had 280
Not no ordinary GTI....
www.mixcloud.com/kells/
  • Back in a Mk3...
Re: discs size
« Reply #7 on: 06 March 2013, 12:27 »
the K plate my brother had was 288 (it was brand new at the time!)
I guess it could be vw's fitting of what they have to hand could mean a few have different specs?
