Golf mk4
Wazzzer
brake disk size 360mm what can i use?
Topic: brake disk size 360mm what can i use? (Read 3532 times)
rio_gti
"i'm not spending any money on it" Got a Hybrid!
05 March 2013, 18:45 »
as above what disks can i use if i have calipers to suite 360mm disks??
maybe a little something else in the pipeline
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
SI74
Re: brake disk size 360mm what can i use?
05 March 2013, 19:18 »
334 R32?
That what I'll be running with the 6 pot Q7 calipers and there a good size.
jonrandom
05 March 2013, 19:33 »
Its just about finding carriers to suit, if you make custom ones you can make any calliper fit any size disc, with in reason.
rio_gti
05 March 2013, 19:50 »
Oh so you don't have to use the standard disk size for the caliper??
So what pads would be used the ones for the caliper?
Wouldn't they overhang the disk??
Don't really know brakes lol
jonrandom
05 March 2013, 20:05 »
Yeah you can go bigger or smaller but not to extremes will just make your breaking worse, the carrier size has to make sure that the pads will be on the right place on the disc.
Yeah can only use whatever pads fit the caliper
rio_gti
05 March 2013, 20:18 »
So will I have to get carriers made up then??
scarr89
Mk4 Golf, DERV FTW!
Reply #6 on:
05 March 2013, 20:23 »
Don't go bigger than you need to. Disks are super heavy. Go for a happy medium with X calliper.
jonrandom
Reply #7 on:
05 March 2013, 20:56 »
Quote from: rio_gti on 05 March 2013, 20:18
Not for definite you can find some depend on your disc/caliper combo. As said you dont want to get massive heavy discs as well as you dont want to get a to big caliper to master cylinder combo. Sure I read that 4 pots work best with our master cylinder but loads of people run 6 pots fine.
scarr89
Mk4 Golf, DERV FTW!
Reply #8 on:
05 March 2013, 21:27 »
What brakes are you aiming on buying? Just tell us...
LCR 4 pots? No, wait, too small for 360, or are they? Just get some LCR 4 pots, will be more than enough, and probably cheaper than what you are thinking of.
rio_gti
Reply #9 on:
05 March 2013, 21:32 »
DB9 4 pot rears
Golf mk4
Wazzzer
