Author Topic: Fitting my tt comps  (Read 1061 times)
Offline Mk2_tel
Fitting my tt comps
« on: 05 March 2013, 14:57 »
I have a tdi130 on Coilovers
Is it worth putting spacers on rears or even front or better look?
If so what is the max width spacer I can go before needin longer wheel nuts cheers
Offline beppe2672
Re: Fitting my tt comps
« Reply #1 on: 05 March 2013, 15:43 »
Ideally you should use longer bolts with any spacers.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline cullygti
« Reply #2 on: 05 March 2013, 20:59 »
to answer your question any spacer over 5mm will need longer bolts upto 5mm you can use your standard bolts  :smiley:
Offline mcgee9t2
« Reply #3 on: 05 March 2013, 21:15 »
<5mm standard bolts.
>5mm longer bolts.
as for do they need spacers. i havent got spacers on mine and my tt comps sit flush with the arches.
depends on what look your going for, if your going for the typical "sceen" streched tyres, stupidly low with sh!t handling then yes maybe 5/10mm front and 10/15mm back
Benny.banks
« Reply #4 on: 05 March 2013, 21:29 »
Unless there the bolt on hubcentric kind of spacer then you can use your standard wheel nut.
Offline cullygti
« Reply #5 on: 05 March 2013, 21:30 »
very good point there dude   :wink:  :cool:
Offline Mk2_tel
« Reply #6 on: 05 March 2013, 22:05 »
Lovely cheers for that guys thought rears might look
Bit small in them big arches but ill give it a go thanks again
