Hello peeps,just fitted mine 2 days ago.creation motorsport tip.on the turbo you need a 5mm hex to undo the bolt,she slips right off.The problem is the coolant line.This can be undone for more access.Follow it all the way back to the block,there is an 8mm hex bolt so you can move it a tad.I didnt bother in the end.i cut the tip down an inch.I cant possibly see how you can get the tip on without cutting slightly or undoing the coolant line.Is it normal btw it sounds like i get a slight flutter now when i lift off throttle????plz
best of luck mate ,well worth doing!!!
