Author Topic: Starting Problems with a Mk3 Golf 2.0 8V Colour Concept  (Read 3370 times)
Offline RainVonBee
Hi, I thought Id join up as this golf is driving me wild and need some input by anyone who's had the same problem!
Firstly, the battery is fine and it recently had a new coil pack due to it blowing the last time this happened.
Let me explain the best I can :)
The car is fitted with an aftermarket immobilizer (No idea what make, a plug and play one). Normally to start the car you firstly remove the immobilizer then put the key in, turn and boom she starts!
But now, you put the key in, turn it, there's no cranking. All the lights on the dash flash frantically and the engine doesnt turn. Unlike the last time this happened I can finally start her after a LOT of throttle and waiting to hear her try and turn.
The stange thing being if once you've got her started and you remove the key and keep starting her from stop over and over it eventually gets easier? Could it be a sticky relay?
Crankshaft sensor has recently been replaced as that was the original fault (Reading around here I see thats a common problem on this model)
Any input would be great, Im a level 3 qualified mechanic but this has me & my fellow college buddies completely stumped lol!!
Golf mk2 1989 GTI 1.8 8V
Golf mk3 1997 GTI 2.0 8V Jazz Blue Colour Concept
Golf mk4 2000 1.6 16V SE
My babies :)
Offline Callum_K
Re: Starting Problems with a Mk3 Golf 2.0 8V Colour Concept
« Reply #1 on: 04 March 2013, 11:19 »
Ignition switches on these are prone to failing, I'd say 99% thats your problem. About £5 for a new one. :smiley:
« Last Edit: 04 March 2013, 11:21 by Callum_K »
Offline Callum_K
« Reply #2 on: 04 March 2013, 11:22 »
Also, its easier to do by removing the whole steering column
http://forums.vwvortex.com/showthread.php?3445064
Offline RainVonBee
« Reply #3 on: 04 March 2013, 12:36 »
Thanks :) forgot to mention she'll start first time with a jump, would that still be the ignition switch?
My babies :)
Offline GOLF-MK3-GTI
« Reply #4 on: 04 March 2013, 13:23 »
Yeah, the next time it refuses to start. Try wiggling the key, it should start if the ignition switch is faulty
Offline Callum_K
« Reply #5 on: 04 March 2013, 13:43 »
Is your battery decent??
« Reply #6 on: 04 March 2013, 13:51 »
or the starter motor?
Offline RainVonBee
« Reply #7 on: 04 March 2013, 13:58 »
Battery perfectly fine, and the starter as that was checked last time it went to the garage
My babies :)
Offline RainVonBee
« Reply #8 on: 04 March 2013, 14:03 »
What caused this problem was lending the car to my otherhalf, who decided he would turn it to ignition, then plug in the immobiliser! Garage has advisedtaking the positive off and trying to wipe the immobiliser codes
My babies :)
« Reply #9 on: 04 March 2013, 14:21 »
I very much doubt it that would be the problem, The job of the immoboliser is to stop car from cranking over. But yeah you could try to leave it for 30 mins or so and see if that helps.
