Author Topic: could it be the battery again?  (Read 1884 times)
Offline adyspriggs
« on: 04 March 2013, 10:33 »
Hi All,
Yesterday after 2000rpm all the guages would zero once i dipped the clutch everything came back then again at 2000rpm would drop off again :sad:
the car starts and drives ok but still the dash is intermittant
i have looked at the battery and it looks like the lid i have put the battery on charge to see if that makes a difference,
recently the dash has started again to be intermittant....last december i had the same problem which was the battery and alternator
cant be the same again could it?
cheers
Ady
« Last Edit: 04 March 2013, 12:48 by adyspriggs »
Offline GOLF-MK3-GTI
Re: could it be the battery again?
« Reply #1 on: 04 March 2013, 13:49 »
Hi All,
cheers
Ady
When you say all the guages, do you mean the temp & petrol needle sits at zero too?. If so then i think you may need new clocks. Also does it show up an error code? Like in the link below:
http://www.golfgtiforum.co.uk/index.php?topic=236162.10
If it does then i think your ECU may have had it, But don't quote me on this  :smiley:
Offline adyspriggs
« Reply #2 on: 04 March 2013, 14:10 »
Yes all guages......
when i turn the ignition on and the car starts once the led mileometer sets to the mileage then all the dials drop to zero
I looked at the dash last yr but the problem was the battery and alternator
maybe i'm living in hope its not them again £££
when you say error code....sorry this is a 1.4CL pretty bog standard  :smiley:
« Reply #3 on: 04 March 2013, 14:16 »
Get your battery & alternator tested, If they are all good. Then i think your clocks are at fault.
Offline adyspriggs
« Reply #4 on: 04 March 2013, 14:22 »
I will give it a go.
cheers for the advice :smiley:
Offline adyspriggs
« Reply #5 on: 04 March 2013, 15:00 »
Unbelievably......
charged battery,cleaned the connections, undid and fastened up the altenator leads drove it and all seems well... fingers crossed
thank you Mr GOLF-MK3-GTI for your suggestions :smiley:
« Reply #6 on: 04 March 2013, 15:22 »
Unbelievably......
No Worries,  :wink:
