Author Topic: Rear wiper Delete  (Read 1215 times)
LakerLover
Rear wiper Delete
« on: 02 March 2013, 13:23 »
Can someone point me into the right direction, Saw a How to with pictures awhile ago now i cant find it  :whistle: Thanks guys
LakerLover
Re: Rear wiper Delete
« Reply #1 on: 02 March 2013, 13:25 »
Was it on Vortex?  :undecided:
Offline damien010685
« Reply #2 on: 02 March 2013, 13:30 »
Google is king bud http://uk-mkivs.net/forums/p/290531/3336039.aspx. The 1 on votex the pics are down
Offline dom
  • Back in a Mk4
« Reply #3 on: 02 March 2013, 13:35 »
Not sure about a guide but it's really easy.
1. Remove the cover from the rear wiper (it pulls off), undo the nut underneath and pull the wiper arm off. It might be a bit stiff, but gently wiggle it free.
2. Open boot, look inside the two handles and you'll see a screw inside each. Undo the screws and give the plastic a good pull and it will come out.
3. You'll be able to see the motor mechanism, undo the plug and water pipe first, then undo the 3 bolts. The motor should then pull off, be careful to not lose the rubber grommet from the glass.
4. I plugged the washer pipe with a screw, then used a new rubber blank to fill the hole in the window. Reattach the trim inside the bootlid and you're done.
LakerLover
« Reply #4 on: 02 March 2013, 14:03 »
Thanks damien the pictures are up on VWvortex now, just done it, f**king looks sweet :D Next step to de-badge the GTI and GOLF badges, any tips guys :D
Also is it worth doing the part in the engine bay? suppose it is, but never used the rear wiper :/
« Reply #5 on: 02 March 2013, 14:45 »
Ahh ok must of been my phone
