Author Topic: 16v overheating in traffic/ stationary, !update! Fans not working. update 2!  (Read 6615 times)
Gavv8
I don't know if it's for 8V or 16V, but it should be same for both.
On second thoughts it can't be the switch, becuase your giving direct live to the fan motor and if they ain't working then you have problems with the fan motor, which is prob burnt out.
Yh that makes sense.  :angry: fecking car!! Can't wait to get rid!
Thanks for all the help bud :afro:
It knows you dont love it anymore..
Offline murraymint
I do love it, but I hardly ever get to drive it like it's ment to be driven, and I can't keep pouring money into it that I'm nit going to make back when I do sell it.
josh
Offline murraymint
Right. I've got a New fan motor. I theory before I go ripping the front of the car off il test it. So I plugged it in. Then I did the sensor bypass test again. And it still didn't work! Should I look at replacing the fan control switch? Help!
josh
Offline Jasikasisback
so you tried testing the fan like in the youtube video and it worked fine? I tested mine earlier and the paperclip heats up really fast,...(gotta be careful as I burned my fingers!)
If that is working as in the video then the fan motor is ok...
Then at least the fan is alright..!
Offline murraymint
Tried that test and it didn't work, with both fan motors I have, which leads me to think its the FCM
josh
Offline murraymint
Right, drove it home, then had to stop in the village  :wink: to post something, after I parked and turned the engine off the fans came on!  :huh:
josh
Gavv8
They do run on if its hot after you switch off.
Offline murraymint
I know but they didn't work at all. I spend money on parts then they go and work!
josh
Offline Djmac
Do you have any idea how they came on? mine work when i bypass the switch, but ive tried 2 seperate switches and the fan still doesnt work at temp?
