Author Topic: Just when i thought everything was OK.  (Read 7781 times)
Offline Ninja
  • 19 smiles per gallon
Re: Just when i thought everything was OK.
« Reply #10 on: 01 March 2013, 20:37 »
VdubNinja,did yours happen when sat in traffic aswell or all the time.Mine only cuts out when engine is hot and stationary its ok when driving.
Happened whenever. Started off stationary I believe, then when I was moving.. Then completely went. Mate it's a 5 quid fix. Worth checking anyway for a fiver. It does sound to me like its a strong possibility though buddy.
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #11 on: 01 March 2013, 20:40 »
Well i've got the whole of March off work so plenty of time to explore.I will defo have a look at the ECU earth tho as i haven't checked that.Cheers m8 :wink:
Offline Ninja
« Reply #12 on: 01 March 2013, 20:46 »
No worries pal.
Battery tray out, check earth is not burnt, maybe even temporarily re earth as a test and see how you go.
My checklist for that issue would be...
Fuel/ecu relay
Coil pack
Spark plugs
Dizzy
Crank sensor
Ecu earth
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 01 March 2013, 20:51 »
Coilpack is a cnut. They do go if you replace with a cheapo one
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline dixie180
« Reply #14 on: 01 March 2013, 20:54 »
New coil pack has only been on about 18 months.New ECU and fuel pump relay about 3 months old,spark plugs 12 months old,new dizzy cap and new crank sensor fitted about 3 months ago too.So looks like ECU earth maybe the answer.
Offline Ninja
« Reply #15 on: 01 March 2013, 20:58 »
 :laugh:
Offline GOLF-MK3-GTI
« Reply #16 on: 01 March 2013, 21:00 »
Coil pack only last me 15 - 18 months lol. Maybe you've cooked it. But you saying that you left it for 20 mins and came back to start it. That's the problem I had with mine. And it was crankshaft sensor. So I dunno maybe yours has packed in, but it shouldn't have.
I've cleaned earths too, but that just helped my lights. Nothing else tbh
Offline dixie180
« Reply #17 on: 01 March 2013, 21:01 »
Forgot to add i've got weird high pitched whirring noise inside the car but can't hear it outside the car with the bonnet up ???
Offline Ninja
« Reply #18 on: 01 March 2013, 21:01 »
Cleaning ecu earth would not really fix the issue.
What happens is water gets under the battery tray and fries the wire from the inside. Best way to tell is to strip it back. If its black, it's burnt. Strip it back until its not black. Mine was burnt right up to the ecu.
« Reply #19 on: 01 March 2013, 21:02 »
How does the ECU temp sensor work?, does it sense the temp and signal the ECU that's it too Hot or sumat?
If it does maybe cox you were in traffic, and temp went up, it may have cut engine off.
