Author Topic: Permanent 12v power output?  (Read 1332 times)
Offline madsb
« on: 01 March 2013, 16:07 »
Hey :)
Bought a remote central locking kit... Where do I connect it for power?
Cheers.
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: Permanent 12v power output?
« Reply #1 on: 01 March 2013, 16:32 »
+ terminal on battery?
Offline Callum_K
« Reply #2 on: 01 March 2013, 16:32 »
Theres a DIY guide in the Maintenance section. Where are you installing it? If in the boot, use the red/white wire from the central locking pump loom.
Offline madsb
« Reply #3 on: 02 March 2013, 14:10 »
The thing is, that I don't have central locking already. I need to install all the actuators too and stuff.. So is my only possibility to connect to the + terminal on the battery? Can't i use the cigarette lighter plug in some way?
Offline madsb
« Reply #4 on: 02 March 2013, 14:14 »
Or maybe theres something around the fuse box?
« Reply #5 on: 02 March 2013, 14:15 »
don't know about ciggy plug but I just had to get a 12v feed from the battery for my sub- if you remove the glovebox and the piece of plastic outside between the bonnet and the windscreen on the passenger side there's a grey bung you can remove and feed your cable through there if you wish
