Author Topic: how to reset service indicator  (Read 1484 times)
Offline mcgee9t2
« on: 28 February 2013, 17:15 »
I know theres a thread in the maintenece but the image wownt load for me??
Anybody able to tell me the steps please
thanks
Offline mcgee9t2
Re: how to reset service indicator
« Reply #1 on: 28 February 2013, 17:41 »
Also another quick one. spark plugs. what size socket should i be using. my 15mm is too small. my 17mm is too big. so guessing its a 16mm spark plug socket? i.e. the one i dont have haha.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 28 February 2013, 18:22 »
With ignition off, press and hold the trip reset stalk on the right. Keep it held and turn the ignition on. Then turn the clock adjust stalk (can't remember which way off the top of my head) and it should go out.
Can't help with plugs as the one supplied in my Halfords kit fits fine
Offline Bellend
« Reply #3 on: 28 February 2013, 21:57 »
Clockwise I do believe. :)
Where all my moneys went.
Offline mcgee9t2
« Reply #4 on: 01 March 2013, 12:42 »
tried turning it both ways, didnt do anything apart from adjust the time 1 hour or 1 min depending on which way i turned it...
Offline mar_k
« Reply #5 on: 01 March 2013, 17:55 »
My Vgate scan tool turns of the service light and able to set between longlife and annual,
Best £35 I have spent.
Offline james2
  • No scammers please.
« Reply #6 on: 01 March 2013, 21:32 »
keep the mileage reset held down when you turn the ignition on and turn the clock button to the right then relese the mileage reset. If its like mine the agu its a bit harder to get it off. maybe my cars trying to tell me something (i need a oil change)  :evil: If it still there after turning the ignition off then back on try this. Hold mile reset down ,turn ignition on ,turn clock button to the right and realse mile button then  :undecided: i think i had  :huh: ill remember tomorrow had to many beers.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline stfc_gti
« Reply #7 on: 01 March 2013, 21:47 »
2002 1.8T GTI AUM, Standard (not for much longer)
