Author Topic: Car cooling when driving....  (Read 2445 times)
Offline madsb
« on: 27 February 2013, 21:03 »
Is this normal? I can sit in the drive for a few mins in idle and the temp will be around 90 degrees, however when I drive for a short period, the temp will drop back to 60-70 degrees... How can I fix this ? Cheers.
Offline tweed
Re: Car cooling when driving....
« Reply #1 on: 27 February 2013, 21:13 »
That is your thermostat buddy. Get a new one
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 27 February 2013, 21:43 »
and get a quality thermostat with new seals...
cheapo's never seem to last/work!
VW BUSH
« Reply #3 on: 27 February 2013, 23:24 »
Its behind the power steering pump if you have one, a black plastic flange with some pipes on it :wink:
Offline madsb
« Reply #4 on: 28 February 2013, 00:01 »
Thanks guys :)
I have to say though, it's not as if the temperature wont rise to 90 when driving at all. It will eventually, after a pretty long period. Do you reckon the thermostat is completely broken or fixable? Any links to ebay or amazon for a new one?
Offline Callum_K
« Reply #5 on: 28 February 2013, 08:53 »
Just get a new one. Try Eurocarparts, GSF, or Carparts4less if you don't want to pick it up (same as ECP but cheaper as online only).
Offline Shady Pioneer
  • graphic designer.
« Reply #6 on: 28 February 2013, 10:16 »
I had this on my Anni, very rarely did I see it go above 70. New thermostat and all has been good since July 2011.
Offline madsb
« Reply #7 on: 28 February 2013, 10:59 »
Awesome, good to hear from someone who has experienced the same thing :) What exactly do i search on? Isn't it called anything other than a thermostat? (not native English :) )
Offline madsb
« Reply #9 on: 28 February 2013, 14:29 »
Nvm which one , found one here in Denmark :) anyway; anyone got at step by step guide on how to do it? thanks guys
