Author Topic: What aftermarket clutches are available  (Read 2090 times)
Offline Chris#101
« on: 27 February 2013, 20:12 »
Im still on my dual mass flywheel and oem clutch at 232bhp & 258lbs ft :grin: and im off to R-tech next month for there stage 2+map using tiv mapping software with a spec capable of 260+ bhp & 300lbsft
So my questions are what 'uprated' clutches are available for the later 6speed gearboxes?
I dont want to spend copious amounts but want one thats going to cope with the torque
thanks :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline mar_k
Re: What aftermarket clutches are available
« Reply #1 on: 27 February 2013, 20:16 »
Not sure weather its suitable but Ive just fitted a Valeo SMF conversion kit to my LCR. Quite impressed so far.
Offline navmk4gti
« Reply #2 on: 27 February 2013, 23:11 »
G60 flywheel and vr6 clutch. Do a search.  :wink:
Offline dan2252
« Reply #3 on: 27 February 2013, 23:44 »
^ the guy said 6 speed so g60, vr6 clutch wont work i think
MK4 golf 1.8 turbo agu :)
Offline turbokid23
« Reply #4 on: 27 February 2013, 23:47 »
The in law is running this cluch at 360bhp and 340lb.
Offline mar_k
« Reply #5 on: 28 February 2013, 17:39 »
Thats great to know, Cheers
Offline Chris#101
« Reply #6 on: 28 February 2013, 18:28 »
A Vr6 set up is old news. As stated I've got a 6 speed box so will be no good  :wink:
Offline Chris#101
« Reply #7 on: 28 February 2013, 18:29 »
No one running big power through their 6 speeds  :undecided:?
Offline mar_k
« Reply #8 on: 28 February 2013, 19:35 »
Look above, The clutch I'm using is being run at 340bhp?
Offline Chris#101
« Reply #9 on: 28 February 2013, 20:25 »
Sorry bud forgot about that. How much did the conversion come to?
Where did you get it from?
 :smiley:
