Author Topic: Help with 17963 error code  (Read 1105 times)
Offline DanJ91
« on: 27 February 2013, 15:21 »
Hi all I've recently changed my n75 valve on my aum after changing my TIP and dv to forge ones and the car pulls fine until i hit 3k revs and then it feels like it goes into limp mode. I've scanned with vag com and i get 17963 error code. Also the car is on the standard map and I've done an n249 bypass (trying to give as much info as possible) I've done alot of searching but haven't found anyone with the same symptoms as mine so any help would be appreciated.
Thanks  :smiley:
2001 AUM - Milltek turbo back with sports cat, S2000 cone filter, Forge TIP, Forge 008 recirc valve, n249 bypass and sai delete, THS FMIC, 42 draft catch can, genuine votex front valance
Offline toby2can
Re: Help with 17963 error code
« Reply #1 on: 27 February 2013, 15:42 »
17963/P1555/005461
Contents
    1 17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
        1.1 Possible Symptoms
        1.2 Possible Causes
        1.3 Possible Solutions
Possible Symptoms
    Reduced power output
    Limp mode
Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
        VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
        Check / Clean mechanism for variable nozzles
Category:
    Fault Codes
hopefully this mite help a bit
2002 Golf Gti AUM
Offline DanJ91
« Reply #2 on: 27 February 2013, 15:53 »
yeah I've had a look at this and can't see anything wrong with pipework etc so im stumped
