Author Topic: Part number lift pump  (Read 4595 times)
Offline Harooshum
« on: 11 October 2003, 02:07 »
I dont wan2b lectured from any1, but it was my last hope and i got a fuel lift pump from GSF.  I told them the right year (i think all mk2's have the same one!) model etc, and when i lifted the boot carpet, I noticed it's a different size.  Fcukers!  A few posts back i was saying about why my car dont work, and this is what happens when you use GSF!
Does anyone know the VAG part number for it on my '91 16v.  It's the one that sits ontop of the fuel tank and located under a round panel under the boot floor.  Cheers
Offline richandhazel
Re:Part number lift pump
« Reply #1 on: 11 October 2003, 11:41 »
Offline Harooshum
« Reply #2 on: 11 October 2003, 13:55 »
Thanks rich that's just wat i'm looking 4!  However there is a big plastic 'union nut' securing the whole assembly from the top.  I cant get it off.  Should be able to unscrew it but cant!  How would you do it?
H.
Offline Fraiser
« Reply #3 on: 11 October 2003, 13:59 »
it should just screw off Harooon
« Reply #4 on: 11 October 2003, 14:08 »
As Fraiser says it should unscrew. Its probably seized on. If you end up breaking it to get it off, let me know and I'll dig out the part number for that too. That number is listed under the 'fuel tank and lines' section.
H.
Offline Harooshum
« Reply #5 on: 11 October 2003, 14:11 »
Actually, i nearly broke my wrists off trying to unscrew it.  I even got a large adjustable ratchet to grab it and twist, and let some others have a go but it still wont budge!  My baby's sick with fuel starvation and I reckon this needs changing, but that fcukin nut is doin MY nut!
Has anyone had probs with this b4? PLEEEEZ
Harry
Offline Fraiser
« Reply #6 on: 11 October 2003, 14:14 »
whne i took one off one i was breaking i took a flathead screwdriver and placed it by one of the ridges on that plastic nut. Used a small mallet and it came off - i only recommend this if you are taking the old one off to replace it with a new one.
« Reply #7 on: 11 October 2003, 14:17 »
I think I had to use a hammer and drift to get mine moving.
Item 19 I think you'll be looking for:-
http://homepage.ntlworld.com/richandhazel1/gti/genpics/files/fueltank.JPG
Blue MK2
« Reply #8 on: 11 October 2003, 17:44 »
Rich where did u find that diagram?
« Reply #9 on: 12 October 2003, 03:39 »
I have an ETKA (VW-Audi parts catalogue) on CD-ROM.
There is an online version, unfortunately its in russian. However with a little patience you can usually find what you're looking for:-
http://www.elcats.ru/audivw/
