Author Topic: anybody kno a good mechanic familiar with mk3's in the ascot area?  (Read 2683 times)
Offline Jasikasisback
went to a local mechanic in bracknell as wanted him to look at the car. told him my concerns that it is running rich. he went through the basics- have you serviced it lately , checked the temp sensor blah blah blah. then said that he's not very familiar with vw's and suggested that i just take it for an extreme rev ride and maybe that will solve the problem. then he said not worth fixing really as repais if major will cost an arm and a leg. told me to drive it until it dies....take off the cat until next mot and drive it until then and don't worry about it. anyways anyone know a good vw mechanic or expert in the area or surroundings?
Offline spudboy6
  • Just like a golf ......
Was it put on vag-com at all ?
will have a fault code in it more than likely which will give you your issue .
and what engine is it ?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Sounds like a very professional and competant mechanic.
yeah, and that's why i need help finding a good one.:)
no fault codes came up. so that is why i am stuck.:(
Offline itavaltalainen
After dizzy was replaced ----- as said in the other thread ----- have you ever bothered to get the ignition timing checked out?
Instead of the VAG 1551 reader VCD/VAGCOM (licenced version) will do
Instead of VAG ignition tester pretty much any can be used....
Mono-Motronic injection and ignition system
Checking and adjusting ignition timing
Special tools, testers and auxiliary items
ı Fault reader V.A.G 1551 or vehicle system tester V.A.G 1552 with
ı 07.93: Cable V.A.G 1551/1
08.93 ı: Cable V.A.G 1551/3
ı Ignition tester V.A.G 1767 or V.A.G 1367 with HT pick-up clamp V.A.G 1367/8
Check conditions
● Engine oil temperature min. 80 °C
● No faults stored in fault memory
=> Page 01-7, interrogating fault memory
Test sequence
ı → Connect ignition tester V.A.G 1767 or
ignition tester V.A.G 1367 with HT pickup
clamp V.A.G 1367/8.
ı Connect fault reader V.A.G 1551 (V.A.G
1552) and select engine electronics
control unit (address word 01); carry out
selection at idling.
=> Page 01-4
→ Indicated on display: Rapid data transfer HELP
Select function XX
ı Input 04 for "Initiate basic setting" and
confirm with Q.
→ Indicated on display: Basic setting HELP
Input display group number XX
ı Input 00 for "Display group number" and
confirm with Q.
(1...10 = Display zones)
System in basic setting 0 ı
1 2 3 4 5 6 7 8 9 10
ı Check ignition timing.
Specification: 4..8 ° before TDC1)
With stroboscope:
ı → Direct at ignition timing notch.
ı If necessary adjust ignition timing by
turning the distributor:
Setting figure: 6 ± 1° before TDC1)
1) Up-to-date specifications:
=> Exhaust emissions test binder
ı Press ı key.
ı Input 06 for "End output" and confirm
with Q.
yes it was checked as when the cambelt was put on the first time it was out by a tooth..VAG was throwing up a fault code (don't remember now) as I never checked the codes after the cambelt was readjusted. So we cleared the code after and it did not come back up.
I am going to have my friend take a look at it tomorrow.
I may end up putting lacquer to clean the catalytic converter (even though no code coming up) Anybody tried this...you add lacquer thinner...not sure if they do this here...:) or if it is ok for vw's
oh i just looked on halfords web page..and the thinner costs 7,50 for half a litre...in Canada you can get a gallon for nine dollars...
Can't understand why it is sooo expensive here...a new cat is cheaper to buy than a gallon of thinner...
has anyone tried this? Take the cat off and soak it in laundry soap overnight to clean it?
Offline spudboy6
You can buy additives you stick in the fuel to clean the cat , not sure how affective they are ,
What are your symptoms / concerns for it running rich ?
I'm no expert on these engines by any shot but I'm a qualified technician for a rolls Royce and Bentley specialist and could always have a quick look at it over the weekend as I'm in henley but the missis lives near Wokingham
Oh and what engine is it you never said it I missed it ?
