Author Topic: Changing waterpump 8v air con model  (Read 1426 times)
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« on: 26 February 2013, 12:33 »
Hi all,
Cars been sat a while with dead water pump and Ive decided its time I got it running again.
Its a 98 8v air con model and I have stripped the car back and drained system etc, removed drive belts and what not but I read online that the alternator is on a spring. I dont think mine is and I cant see a way of getting the alternator mount off to access the waterpump underneath, its driving me nuts!
Does anyone have any ideas?
Offline itavaltalainen
Re: Changing waterpump 8v air con model
« Reply #1 on: 26 February 2013, 12:40 »
with AC you would have a tensioner for the belt (unlike non-AC version where a spring indeed sits under the alternator to tension belt).
item 4 is your setup....
I would think that you have to remove (not disconnect it from pipes thou!!) the A/C compressor and alternator obviously
Offline MK3 Menace
« Reply #2 on: 26 February 2013, 12:43 »
Thats looks right to me how it is, I have the alternator off, its just getting the alternator mount off really, once thats out the way I think I will be ok. I think I might just have to be a bit more aggressive and not worry about breaking bits.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 27 February 2013, 00:09 »
Have you removed all four of the block mounting bolts that hold the bracket on,  if so you may need to give it a gentle persuasion with a rubber mallet to break the seal.
Offline MK3 Menace
« Reply #4 on: 27 February 2013, 15:11 »
Nope thats where I got upto, I think the gentle persuasion will have to wait till the weekend but I think once i get that off ill be well away.
« Reply #5 on: 27 February 2013, 15:18 »
A deep socket will help but isnt essential if you have the standard length socket half inserted on the extension bar.
