Author Topic: Air flow meter  (Read 3009 times)
Offline stevends
Air flow meter
« on: 25 February 2013, 18:17 »
Mite sound stupid but do u need the air flow meter on ur car or can u run it with it off ?
MK4 Golf 1.8 20V turbo, piper cross induction kit with heat shield, forge 007P dump valve, coilover and a remap !
Offline itavaltalainen
Re: Air flow meter
« Reply #1 on: 25 February 2013, 19:09 »
it will run with it off, using replacement value....
that is sh!te on naturally aspirated engines already but there you got throttle body potentiometer so it can "guess" how much air is going in.
add a turbo and you got another variable.... so the replacement value will be even less close to the real deal...
which will result in:
loss of power,
lower mileage,
probably MOT failure,
check engine light coming on....
and finally you'll f**k your cat.
« Last Edit: 25 February 2013, 19:18 by itavaltalainen »
Offline dom
  • Back in a Mk4
Re: Air flow meter
« Reply #2 on: 25 February 2013, 19:15 »
Why would you want to remove it?
Offline Dalo Harkin
Re: Air flow meter
« Reply #3 on: 25 February 2013, 19:23 »
I know people with massive spec jap cars running without them, I wouldn't recommend it on a golf
Offline barrym381
Re: Air flow meter
« Reply #4 on: 25 February 2013, 19:24 »
well he is irish  :grin: :grin:
Offline Dalo Harkin
Re: Air flow meter
« Reply #5 on: 25 February 2013, 19:31 »
 :grin: :grin:
Potaaaaaaaaato
Offline stevends
Re: Air flow meter
« Reply #6 on: 25 February 2013, 19:46 »
I'm British u knob !
Offline Dalo Harkin
Re: Air flow meter
« Reply #7 on: 25 February 2013, 19:49 »
Lmfao internet is great for misinterpretation
Offline stevends
Re: Air flow meter
« Reply #8 on: 25 February 2013, 19:51 »
It's not working. When it's contacted the car not running right but when u take it off it goes like sh!t of a shovel !
Offline barrym381
Re: Air flow meter
« Reply #9 on: 25 February 2013, 19:53 »
well in that case its f**ked ya knob so replace it  :grin: :grin:
