Golf mk4
Wazzzer
Instrument cluster
Topic: Instrument cluster (Read 1188 times)
Perryd84
GTI forum regular
MK4 Golf 1.8T 20V GTI
Instrument cluster
25 February 2013, 09:57 »
I have a 1999 AGU 1.8t GTI and the instrument cluster does not have the LCD display in the center of the console which the later 2000 upwards models do.
I'm thinking of fitting a cluster off of an anni/Bora sport but want to know if anyone has done this and the LCD display works correctly??
I have vagcom and will be able to code it but want to know if it will work with my 99 AGU engine before I waste my money?
Last Edit: 25 February 2013, 12:31 by Perryd84
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Perryd84
GTI forum regular
Re: Instrument cluster
25 February 2013, 15:02 »
Bump! Any help on this??
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
25 February 2013, 17:02 »
Been and done this, look in my project thread for more info. You'll need VAG TACHO as well as VAG COM to code the clocks in. Also the wiper stalk with control buttons, outside temp sensor, some wires and a bit of patience. But yes it can be done
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
dom
10k hero
Back in a Mk4
25 February 2013, 17:10 »
Also have a look at this thread:
http://uk-mkivs.net/forums/t/167146.aspx
Perryd84
GTI forum regular
25 February 2013, 20:29 »
Cheers guys I'll have a read up of them threads and give it a go.
Thanks again!
Golf mk4
Wazzzer
Instrument cluster
