Author Topic: 3" turbo back exhaust  (Read 1843 times)
Offline Gary022
« on: 24 February 2013, 23:50 »
So after it it sitting on my garage floor for 6 months I finally got round to fitting my ebay special exhaust.
The problems I encountered while doing so where:
Turbo down pipe gasket holes needed to be drilled out for it to sit flush
Front lambada hole needed to be plugged and a new nut welded on the other side as the sensor wouldn't fit on its original position.
Centre section needed extended
New sensors were bought as the old ones threaded when removing ( unlucky I guess )
New clamps were purchased as the ones supplied were as useful as a chocolate fire guard ( knew this before )
Mounting rod on the back box that goes over the rear beam needed grounded off and welded on lower down to allow enough clearance over the beam.
Despite all this the beast is on and sounds pretty sick.
Only slight issues I have now is despite raising the exhaust over the rear beam it still just rattled when driving a slow speed low revs. To help this I've secured a thick piece of rubber onto the beam and this has almost silenced it , it now only vibrates rather than rattle. Read on a post on here that apparently heat wrap helps cure this so I've bought some of that to see if that can cure it. The heat shielding has a mini rattle somewhere aswell so when I'm under ill hunt and cure that aswell.
All in all I'm pleased with the results but recommend anyone attempting this job to go into it with an open mind .. And a welder.
« Last Edit: 25 February 2013, 13:52 by Gary022 »
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline dom
  • Back in a Mk4
Re: 3" turbo back exhaust
« Reply #1 on: 24 February 2013, 23:57 »
The source of my heatshield rattle is the hangers near where the cat should be, they are slightly too long so touch the heatshield slightly :wink:
Offline Gary022
« Reply #2 on: 24 February 2013, 23:59 »
Could be the same here , I'll have a look this weekend when I wrap the part going over the rear beam and Stick the cover over the lambadas which I forgot to do.
Mk4 Golf Gti 1.8T
Offline Gary022
« Reply #3 on: 25 February 2013, 08:17 »
Boo engine management light came on this morning lol. I'm guessing this can be switched/mapped off when I get a remap on the car?
Mk4 Golf Gti 1.8T
Offline Granta Gti
« Reply #4 on: 25 February 2013, 08:24 »
What engine code have you got?
Offline Gary022
« Reply #5 on: 25 February 2013, 08:27 »
Not sure , don't have anything to scan it. Just the engine lights come on
Mk4 Golf Gti 1.8T
Offline rio_gti
« Reply #6 on: 25 February 2013, 10:26 »
i had this too, just cut 10mm off either side  :wink:
Offline GTi_James
« Reply #7 on: 25 February 2013, 10:29 »
lift your engine cover and it should be a stamp near the bottom left as you look down on it  :wink:
Offline BarryMKIV
« Reply #8 on: 25 February 2013, 10:30 »
I wouldn't be surprised if it's 16804.
25th Anniversary GTI 1.8T No. 0441
Offline Gary022
« Reply #9 on: 25 February 2013, 10:35 »
It will definaetly be 02 sensor related because it won't be sensing a change in temperature or flow between before and after cat as both sensors are before. Won't cause me any damage driving like I am tho? It's not entering limp mode or anything. Planning on getting a map in summer so surely be able to make the sensor think its doin the right thing
Mk4 Golf Gti 1.8T
