Author Topic: head unit problems help!!!  (Read 2544 times)
Offline 67buggers
« on: 24 February 2013, 22:50 »
Head unit has died....i was listening to it and it just turned off....checked the head unit fuse and the fuse box and both ok!
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: head unit problems help!!!
« Reply #1 on: 24 February 2013, 23:05 »
flat battery?  :evil:
Offline 67buggers
« Reply #2 on: 24 February 2013, 23:07 »
Negative...over
Offline Leroy
  • Golf GTI Anniversary 16v
« Reply #3 on: 25 February 2013, 10:05 »
any smoke came out the back of it???
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #4 on: 25 February 2013, 12:25 »
What HU is it mate?  Is it running off the standard wiring loom or has it been cut into at any time, as in electrical tape, connector blocks etc?
Offline 67buggers
« Reply #5 on: 25 February 2013, 15:42 »
Its a sony xplod....its pluged.into.the original harness and no.cut wires....i took the head unit to a repair.shop.today who.have had it running and said.its fine so it has.to.be car wiring end
Offline trog_nfs
« Reply #6 on: 25 February 2013, 15:47 »
Check it has 12v both permanent and ignition.
I have a feeling the ignition live has failed.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 25 February 2013, 16:14 »
Do you live near Milton Keynes mate as more than happy to have a look.......I am not bad with electrics, mechanical stuff and I don't have a clue!
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #8 on: 25 February 2013, 17:33 »
One way to get it working is by giving it a direct feed from the battery mate with an in line blade fuse holder.
So.......
http://www.ebay.co.uk/itm/AUTOMOTIVE-SINGLE-CORE-ELECTRICAL-CABLE-RED-17-Amp-4-M-/370755248526?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5652bc218e
Use the earth wire from your loom and the above direct to your HU power wire.  I always like to solder and wires then heat wrap them so nice and secure. Also the fuse used in the Ebay ad' is a 30, I would use a 20.
Offline murraymint
« Reply #9 on: 25 February 2013, 20:38 »
Random one, and might help you might not. But my old head unit used to do the same, it was a blue wire on the back onit that had a 'mute' label onit, that used to short again the unit and turn off the hu. Put some tape onit and never happened again. Jus sayin  :wink:
josh
