Author Topic: red coolant temp light flashing  (Read 2691 times)
Offline hotdogsmale
  • You just cant go wrong with a golf!
« on: 24 February 2013, 10:50 »
Hi guys just a slight problem im having. First thing in the morning the light starts flashing red but if i tl run it for 10 mins or so and turn off then on again it goes :-\ and dosnt come on until the next morning hmmm any ideas guys? Cheers
Offline itavaltalainen
Re: red coolant temp light flashing
« Reply #1 on: 24 February 2013, 10:59 »
The light will come on if temp goes over the top (me thinks 120) or coolant level is low.
If it comes when engine is cold and coolant level is between min and max try to add more coolant, so it is just a bit over max. This should cure the red light, if not try to clean the low coolant sensor (electrodes) with an old toothbrush - should this not help check wiring to expansion tank or possible expansion tank swap.
Also worth measuring the coolant temp sender (posted an image here, just look in a recent temperature related thread)... but if this went wrong you'd probably notice since the temp gauge would show high temp...
« Last Edit: 24 February 2013, 11:04 by itavaltalainen »
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #2 on: 24 February 2013, 11:01 »
You checked coolant level ?.If not it could be a faulty coolant level sensor in the coolant resevoir.
Offline tweed
« Reply #3 on: 24 February 2013, 11:23 »
If the level is good then put up with the light or replace the sensor on the expansion bottle
Offline hotdogsmale
« Reply #4 on: 25 February 2013, 13:23 »
Level if fine i think maybe ill trya cooland charge or get a expansion bottle cheers for very quick reply guys
