Author Topic: Rear driver window has dropped. Help!!  (Read 4535 times)
Offline GOLF-MK3-GTI
« on: 23 February 2013, 19:26 »
As above my rear driver side window has dropped. I can hear the motor, but its not bringing the window up?, ive not opened it yet.
What could be wrong?
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: Rear driver window has dropped. Help!!
« Reply #1 on: 23 February 2013, 19:49 »
take off the door card and have a look. most likely it's a plastic clip that's broken, should be a cheap fix if so. could be a broken cable also. only way to find out is to have a look and see what's broken  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 23 February 2013, 20:23 »
This
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #3 on: 23 February 2013, 20:38 »
I'm going to have a look at it tomorow, I've parked it up in me garage for the night. One question is are the MK3 mechanism like the MK4's. Me brother MK4 window clip brown and eventually the cable chewed itself up. Coz he kept on messing about with the window switch lol,  Hope I ain't done the same to this  :cry:
« Reply #4 on: 23 February 2013, 21:24 »
even so you can get a new cable for about 12.50 and fit it to the existing mech. a little fiddly but ok to do
« Reply #5 on: 23 February 2013, 21:31 »
Okay if that is the case. I'll just get a new mechanism off eBay. So take old one out and replace it with new one. Save time doing the fiddly bit
if I'm right the MK3's are not held using rivets are they?
Offline Ninja
  • 19 smiles per gallon
« Reply #6 on: 23 February 2013, 21:39 »
Correct. 20 min job to swap it all. If that.
« Reply #7 on: 23 February 2013, 21:41 »
such an easy job if you just replace mech
« Reply #8 on: 23 February 2013, 21:45 »
Sweet. I'll take it apart and see what's the crack with it. Will let you know how I get on. :smug:
one last question?, if I only need the clip?, where can I buy them from?
Offline Ninja
« Reply #9 on: 23 February 2013, 21:59 »
TPS, eBay?
