Author Topic: Relays in 1.8 AAM automatic. Which one is for ECU?  (Read 1698 times)
Offline Jasikasisback
« on: 23 February 2013, 17:42 »
Hi I have the following relays in my car and I think these are what they are for: I have a 1.8 auto AAM
72-rear wiper relay
99-front wiper relay (intermittent)
36-headlights warning relay (buzzer when you open the door?)
18-load reduction-lights, defogger etc, (when you crank the car diverts all power to start car)
53-general electrics-horn, fog light
167-fuel pump
191-hazards
175-automatic transmission relay
so which one of these relays are for the ECU? I was unable to garner that info.
I've got all spare relays except for 175...so I am hoping one of them is the culprit.
Anyone know which one it is?
Thanks in advance.
Offline Screech16v
  • MK3 20vt AGU
Re: Relays in 1.8 AAM automatic. Which one is for ECU?
« Reply #1 on: 23 February 2013, 17:48 »
30 ,32 or 109 depending what ECU it has, got info from A2 resources .
« Reply #2 on: 23 February 2013, 17:50 »
i don't have any of those relays on my car..i just have the ones mentioned above in the fusebox
is the ecu relay located somewhere else?
« Last Edit: 23 February 2013, 18:01 by Jasikasisback »
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 23 February 2013, 18:02 »
Just had a quick google and read that spi doesn't have a relay for the ecu only mpi  :shocked:
Offline itavaltalainen
« Reply #4 on: 23 February 2013, 18:10 »
yep... mono motronik does not have an ecu relay.
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 23 February 2013, 18:18 »
I have to agree..... spi is non ecu relay'd
« Reply #6 on: 23 February 2013, 18:29 »
cheers for that
