Author Topic: what is under the heat shield that is behind the motor?  (Read 1307 times)
Offline Jasikasisback
I'm asking this as I have most likely dropped a socket behind it and can't fish it out while I was putting the thottle body back on.  I'm just wondering if it can just sit in there and I don't have to worry about it or do I need to get at it and remove it.It is just a 11mm socket, so not the biggest of things and it did not fall out when I moved the car. It had a little gap but now I have pushed it closed. Every other time it has fallen onto the ground, but not this time!.
Gavv8
Re: what is under the heat shield that is behind the motor?
« Reply #1 on: 23 February 2013, 15:32 »
Exhaust manifold.
Offline tweed
« Reply #2 on: 23 February 2013, 15:57 »
You mean the heat shield on the car?
I don't think you got anything to worry about mate.
Should remove it because it can come out while your traveling bounce on the road and damage a car, possible cracking a screen. But won't harm your car.
« Reply #3 on: 23 February 2013, 17:18 »
thanks, then will just leave it if I cannot get to it..but will try my best as I don't want it to fall out and damage someone else's tyres
Offline tweed
« Reply #4 on: 23 February 2013, 17:23 »
But tyres. Paint and glass.
That will dent a car or crack the front screen.
