Author Topic: Loud ticking/squeaking noise.  (Read 1338 times)
Offline Scott-R
  • GoT BoosT!
« on: 22 February 2013, 20:23 »
Theres a ticking/ squeaking noise coming from my engine bay between the scoosh filler and the power steering on the left it could be something to do with fueling.. is that the fuel filter?
No noise on idle only when picking up speed.
Any help would be great thanks.
Golf GTI ... What else would you have?
Offline beppe2672
Re: Loud ticking/squeaking noise.
« Reply #1 on: 22 February 2013, 21:42 »
I think you're on about your charcoal canister mate. Mine ticks, cant really find a definitive answer weather its supposed to do it an idle. If it really bothers you you could do a charcoal canister delete.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Scott-R
  • GoT BoosT!
« Reply #2 on: 22 February 2013, 21:42 »
After some googling, it's the carbon canister that's making the noise anyone had this before?
Should I replace it or clean it?
Can I run it if its making these noises?
Offline Scott-R
  • GoT BoosT!
« Reply #3 on: 22 February 2013, 21:43 »
Mine doesn't do it on idle only under load.
Yours run ok ticking?
Offline beppe2672
« Reply #4 on: 22 February 2013, 21:46 »
link for the delete http://www.golfgtiforum.co.uk/index.php?topic=222678.0
As far as I know it releases fuel vapor from the tank into the inlet system. The only issue I can figure out is that it's putting un-metered air and fuel vapour into the intake. I'll be doing this delete on mine soon!
And yeah my golf runs fine!
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #5 on: 07 March 2013, 22:32 »
The ticking is normal, it's a PCV valve opening and closing to allow the gas flow through the canister. Unless it becomes stupidly loud then it shouldn't be a problem.
I thought Volkswagens were supposed to be reliable?
