Author Topic: Sorry but..... ford transit help pls  (Read 1995 times)
Offline jonrandom
« on: 22 February 2013, 15:51 »
Ive got a mk6 03 ford tranist and it had all the usual gear selecting problems so I replaced both linkages then after that the gears locked and I could only get 1st and 2nd.
I swapped the gear selector for a new one and I now have all gears but when I select reverse it clungs into gear then drives forward! All the other gears are fine but I just have no reverse.
Anyone have any ideas pls?
Offline danny_p
Re: Sorry but..... ford transit help pls
« Reply #1 on: 23 February 2013, 10:10 »
FWD transit ?
all the VW's have gone bar 1.
Offline danny_p
« Reply #2 on: 23 February 2013, 10:13 »
you need to adjust the cabels,    theres clip things on them you can undo and it allows you to adjust there length.
if doing on your own you put it in gear,  unclip the cabel adjuster   ( gear stick end of cabel )  then nudge the gear stick slightly away from the gear it wont reach  then put the clips in and try it.
right twerp on your own to do
Offline jonrandom
« Reply #3 on: 23 February 2013, 17:23 »
Yes mate fwd, ok nice one will give it a go once the mrs gets home  :smiley:
Offline jonrandom
« Reply #4 on: 24 February 2013, 13:44 »
Cheers for your help mate its all sorted now they make it easy on the transit once you know how. There is a bolt to lock the gear stick in place then just need to reset the cables to the right length and thats it sorted  :smiley:
Offline danny_p
« Reply #5 on: 26 February 2013, 00:18 »
mine never had that bolt or i never found it  :sad:   when it chose to do the same thing at strencham services one night  in the rain.
Offline jonrandom
« Reply #6 on: 26 February 2013, 21:38 »
Harsh one mate, that does not sound like fun!
