Author Topic: k03 with k04 internals. any good?  (Read 4906 times)
Offline pete_20vt
« on: 22 February 2013, 03:44 »
Still tryin to learn more about turbos so I no its probly a sily question lol
I no the is a k03, k03s & k04 so wots the big differents between all of them?
Thanks
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: k03 with k04 internals. any good?
« Reply #1 on: 22 February 2013, 13:00 »
Ko3s has a better waste gate than the ko3 iirc.
Ko4 is just a bigger turbo. Turbine wheels are larger.
Offline Chris.
« Reply #2 on: 22 February 2013, 23:58 »
Turbine wheel larger as well as housing on the k03s is different to that of a k03.
K04 completely different.
Beach buggy turbos doing some interesting developments on the k03 frame at the minute.
Click For Build Thread
Offline emery1990
« Reply #3 on: 27 February 2013, 17:26 »
You can get a k03 hybrid, it has k04 internals, worked out cheaper than swapping over the k04, only needed like 3 things, but it has stage 3 mapping at £700.
People have  been getting 280odd.
Do a search on it.
Offline beppe2672
« Reply #4 on: 05 March 2013, 12:26 »
It's a bit more complicated than just K03, K04 etc. Borg warner/kkk's clasification system is pretty complicated, compressor wheels are identified by a 4 digit number. the first 2 are the exducer size in 10th's of an inch, the seccond 2 are the size of the inducer given in a percentage of the exducer, for example a 2275 wheel has a 2.2" exducer, 1.65" inducer (75% of 2.2) ! Heres a breif rundown of the differences between the turbos most people fit to their mk4's:
K03-K03s differences, K03 has a 2073 compressor wheel, K03s has a bigger/better 2075 wheel, exhaust side is exactly the same. (same turbine, same 22mm wastegate)
K04-001 - similar 2075 compressor wheel as the K03s, slightly larger turbine, larger wastegate, direct replacement for the K03/K03s
K04-02x - 2275 compressor wheel, larger turbine than the K04-001, will not fit a mk4 without buying a different exhaust manifold, downpipe, tip etc.
There are literally hundreds of different variations of K series turbo's.
Hybrids, here's a pretty damn epic thread by dan aka littco aka beachbuggy.
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/139858-hybrid-turbocharger-k04-build-3.html
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
