Author Topic: distributor oil leak  (Read 1199 times)
Offline YODI
« on: 27 July 2005, 23:31 »
hi guys, my j plate 16v is leaking oil from the dizzy and leaks into the cap , does it need a new one or is there just an 'O' ring i can change ? ?
Offline AlanMK216v
Re: distributor oil leak
« Reply #1 on: 28 July 2005, 21:31 »
ttt for the man..
I also need to know this
VeeDubGTI16v
« Reply #2 on: 29 July 2005, 10:52 »
this is an annoying one as the o ring you need is a half size, and not easily available so you need a new dizzy really. mines been leaking for about a year now :grin:
Offline kniterider
  • had most, sold most and often buy more!
« Reply #3 on: 29 July 2005, 11:44 »
feck buying a new dizzy for the sake of an o ring!!!
try and get the o ring size and i will 99% be able to get you one either through some1 at my work or ill order one from bsl, infact ill do a bit of home work now as im bored......
Gaz
why go paying £60-90 for a dizzy when an o ring will cost you no more than 20p... madness!!
Offline YODI
« Reply #4 on: 29 July 2005, 11:59 »
If I know you can change just the 'o' ring then thats what ill do :D
