Author Topic: Clutch Cable adjustment manual/automatic  (Read 2656 times)
Offline myv8growler
« on: 21 February 2013, 14:16 »
Hi guys.
My clutch pedal sits slightly higher than the brake pedal
and the clutch bites really high on the pedal travel.
This is my clutch cable
is this a manual or automatic adjustment cable?
If its a manual, how do I adjust it so the clutch bites lower down the pedal movement?
regards
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Clutch Cable adjustment manual/automatic
« Reply #1 on: 21 February 2013, 17:48 »
Thats a manual clutch cable...
To adjust undo the bolt at the bottom of the white bit and twist it accordingly and re-tighten the nut when happy!
For More Info Click To See;
Offline myv8growler
« Reply #2 on: 21 February 2013, 19:06 »
dont mean to sound like a total div, but which way will tighten it (lower the biting point)?
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 21 February 2013, 19:11 »
TBH Can't remember but one way tightens it and the other loosen's it... ;)
:afro:
Offline dragonfly
« Reply #4 on: 21 February 2013, 19:44 »
The gap between the bottom of the adjusting sleeve (the white bit) and the base of the bracket (where the rubber grommet is) should be 12mm.  Anti-clockwise to loosen the nut and turn the sleeve.
Offline myv8growler
« Reply #5 on: 21 February 2013, 21:28 »
thanks, i'll give it a go tomorrow
so if the gap between the white bit and the base is shortened will that tighten the clutch?
Offline Tomonator1985
  • Low 'n' Slow
« Reply #6 on: 22 February 2013, 07:12 »
make the gap between the "white bit" and the....."bottom bit" wider. That should bring the clutch back down.
*MK2 Golf GTI 16v Small Bumper*
Offline myv8growler
« Reply #7 on: 22 February 2013, 14:02 »
do I need to put the clutch pedal under any load to adjust the cable?
Offline dragonfly
« Reply #8 on: 23 February 2013, 21:01 »
No. If after setting the right gap there is too much play or the pedal is too high consider replacing the cable.
