Author Topic: 1.8 16v - CLUTCH PEDAL NOT RETURNING - HELP  (Read 2137 times)
Offline Tomonator1985
  • Low 'n' Slow
« on: 20 February 2013, 17:53 »
Hi guys
Cant get it in gear at all!
clutch lever arm moves up and down freely and does have resistance.
pedal will not push pack to the original position.
it is a manually adjusting clutch but i've adjusted it both ways on the cable and have replaced the cable.
ANY IDEAS WELCOME!
*MK2 Golf GTI 16v Small Bumper*
Offline emery1990
Re: 1.8 16v - CLUTCH PEDAL NOT RETURNING - HELP
« Reply #1 on: 20 February 2013, 21:13 »
Have you had the clutch changed recently ? This happened to mine but luckily just needed adjusting.
  • Low 'n' Slow
« Reply #2 on: 21 February 2013, 08:02 »
No havent had it changed since ive had it. So it is the actual clutch you think?
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 21 February 2013, 08:22 »
Check your clutch pedal (a guy who works with me had same issue his clutch pedal broke but i dont know were from. Can you pull it back up? And if you can what happens when you press it back down?
*****MK3 Anniversary*****
*****MK4 GTI T*****
  • Low 'n' Slow
« Reply #4 on: 22 February 2013, 07:09 »
i can push the pedal down and pull it back up but it wont come back up on its own.
lever arm moves up and down fine.
just seems like there isn;t enough tension to pull the pedal back to the starting position.
