Author Topic: project 1989 mk2 golf gti 16v - slooooowwww  (Read 1718 times)
Offline z1mma
« on: 20 February 2013, 16:54 »
Hi all
recently came across a 1989 mk2 gti 16v, with 190k, it was suppose to be a daily but decided against it.
im now looking at  restoring it, unfortunately im not as skilled in restoring as most of you guys so some basics things i will be able to do myself but majority of it would be sent out and done professionally.
I plan to have a 1.8t conversion done, im looking into buying a donar car, but not sure if it will work out cheaper or more expensive if im not able to salvage everything from it.
body looks in ok condition and from what i could see it may not need too much welding, im not sure if i should fix all that before doing the conversion or maybe do after the conversion when a lil more money becomes available.
heres a few pics, ive taken then trim off to see if any rust around body etc..
Current
Audi S3 8p
H&r springs 25mm | H&R spacers| Milltek exhaust | Induction kit | Autotech HPFP with new cam follower | RS4 Fuel pressure regulator | Later spec ā€œDā€ Recirculating valve | Revo stage 2+ Software | Uprated LOBA sach clutch | Forge Twintercooler
Audi A4 b7 2.0TDi S-line  - work horse!
Offline Thom89
  • Looking for an "Icebreaker"
Re: project 1989 mk2 golf gti 16v - slooooowwww
« Reply #1 on: 26 February 2013, 21:50 »
No pics showing, upload pics to "Photobucket" copy, then paste the IMG code to your thread
Thom
