Author Topic: changed all 3 engine mounts still get engine wobble!  (Read 1971 times)
Offline dragongreengolfgti
  • my golf gti mk3
« on: 19 February 2013, 19:54 »
Evening all
My problem is I have just finished replacing all 3 engine mounts with parts from euro car parts front mount I done about 5 months ago, gearbox mount last month and weekend gone the other rear mount. Two weeks ago I also done new top mounts and bearings and last year I fitted new wheel bearings, ball joints and drop links  :smiley:
Now I thought that would be the end of my kangaroo action albeit it's now a lot better and nearly gone I can still feel a little judder when slowing down or at first acceleration!  :sad: I think my gearbox is on it's way out as getting a grind into second (after changing oil) and/or clutch is going can this affect things? Also drive shafts is this possible? Anything else I need to look at maybe?
Offline spikenipple
Re: changed all 3 engine mounts still get engine wobble!
« Reply #1 on: 19 February 2013, 20:46 »
It's probably the weight shifting from/to the suspension.
Offline CJA321
« Reply #2 on: 19 February 2013, 21:17 »
Front subframe bushes maybe? The 4 bushes that hold the front subframe to the chassis legs, as thats attatched to the front engine mount
  • my golf gti mk3
« Reply #3 on: 19 February 2013, 21:46 »
Hmmm yes maybe although all of the underneath bushes are poly done by previous owner i've had it coming on two years and not sure when they we're done i suppose they could be worn maybe not sure though? cheers
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 20 February 2013, 08:41 »
Polys may even be the cause of the extra transferred movement due to less dampening ability than the oem rubber mounts .
Offline tshirt2k
  • Been there...Done that...
« Reply #5 on: 20 February 2013, 15:13 »
You could also have play in your cv joints, i had this recently, but loose wheel bolts can give the same effect. To remove the movement significantly fit pucks as a front mount to replace the swiss cheese one. :wink:
Mk3 ABF 16VT Megasquirt V3
  • my golf gti mk3
« Reply #6 on: 20 February 2013, 17:22 »
Yeah i have read they can do i was under the car at weekend and tried wobbling things around etc and couldn't get anything to budge  :sad: might get my mechanic friend have a look on the ramp for me  :smiley:
One of the cv joints was replaced last years mot time but could maybe the other i do get a weird sensation when givig it some beans around a small corner like something under the front is moving. I replaced all the front hubs and new wheel bearings also perhaps its the coilovers giving up?
