Author Topic: Rust (Pic included)  (Read 2630 times)
Offline Logie
Rust (Pic included)
« on: 27 July 2005, 18:58 »
  I know its not the best picture but im just hoping this is nothing serious as this is the only prob with my MKII GTI.
Whats the best way to resolve this? And does it look like a windscreen out jobbie or is it best to sand it all down first to see how bad it is?
Thanks in advance for any input
Offline ...joe
Re: Rust (Pic included)
« Reply #1 on: 27 July 2005, 19:07 »
i can't tell but i'd think that therust will go under the rubber so to make sure you get it sorted it'll have to be a windscreen out job. you may as well do it right! or try to peel back as much of the rubber as you can to see how bad it is..............
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline monzablue16v
« Reply #2 on: 27 July 2005, 19:20 »
yeah dude do it quickly can't find pics at mo but there was a bubble like that on my boot and it had been left for a while me thinks :( hang on.....
Before
After
So yeah a speedy windscreen out job and fix it before it starts slinging it down constantly again! otherwise this  is what you have to look forward to rust spreads on these old busses! :D good luck and i hope it's only a little bubble dude. ;)
Offline Logie
« Reply #3 on: 27 July 2005, 20:32 »
GOD DAM at those last pics :O How much did it cost you to get that sorted mate? And what type of costs to get it sorted properly? I cant afford to be anally raped :/
 Or if the Windscreen comes out alright i could do it myself this weekend? Its not leaking any water or anything. I pressed hard on it to se if i could hear cracking etc but it was fine. Will try peeling the rubber back if it stops raining tonight.
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 27 July 2005, 20:36 »
if it's as bad as monza's I'd be thinking about a new tailgate!
Go see a bodyshop and get a quote to repair that logie. soon it'll start letting in water :(
Mk4 Golf 150PD
« Reply #5 on: 27 July 2005, 20:37 »
Think it's the scuttle panel dude?????
It cost me £50 for a new bootlid and about 4 hours messing about with spraypaint and window rubbers (wrong lip :ahem:) lol the windscreen isn't too bad to take out use some clothesline when putting it back in to pull the rubber over the lip much easier 2 person job though! getting it out is fun mind you!
Get it sorted yourself shud b ok if it's not too far gone good luck dude.
Offline Dizzie
« Reply #6 on: 27 July 2005, 20:41 »
I got a tailgate off ebay for 99p :D
it's 99% rust free with a tiny winy little bit round the number plate holes.
it'll be £200 to get it modded and sprayed how I want it.
Mk4 Golf 150PD
« Reply #7 on: 27 July 2005, 20:48 »
looks better now though you want it to look anything like this Dizzie?
or is it just me? :D
Offline Logie
« Reply #8 on: 27 July 2005, 20:50 »
Looks good. Dont suppose you could do a quick guide on how to remove the windscreen and how to refit it? I'd be very greatfull!
« Reply #9 on: 27 July 2005, 20:59 »
Not really the person for that my techniques have been described as "bodge master-tastic"
My way consisted of pushing it out with my feet from inside and been caught on a blanket on the bonnet by a willing friend! can go disasterously wrong but I was changing mine so wasn't too bothered, putting it back in you need to put the rubber around the window.Then run string, wire etc inside the rubber seal that goes over the metal lip, put in place and whilst your helpful buddy pushes on the screen you pull the string out lip goes over the rubber and job done unless you put the string in the wrong gap :ahem:!  someone may be able to help on here with a less neanderthal way but that's how I did it and it worked fine. It's not as hard as it seems really :D
