Author Topic: uprated rear brakes on a 16v mk3  (Read 6189 times)
Offline whileoceanasleeps
  • patience comes to those who wait.
« on: 18 February 2013, 21:11 »
hey, all my discs and shoes are in need of replacement all round and I was thinking - how hard is it to put 288 (or whatevwr they are) front discs on the rear? if I need to replace anyway The actual disc cost wouldn't differ much. would it be as simple as pulling front calipers on the rear?
thanks
sorry about typing I'm iPhone lazy
Offline Screech16v
  • MK3 20vt AGU
Re: uprated rear brakes on a 16v mk3
« Reply #1 on: 18 February 2013, 21:13 »
Absolute waste of time as the rears don't need brakes any bigger than what you have already as most of the braking is done up front anyway .
Offline murraymint
« Reply #2 on: 18 February 2013, 21:14 »
No point as that will make the rear lock too easy. All the weight shifts to the front when braking, hence big brakes on the front
Edit: unless your sh!t hot at reversing  :laugh:
josh
« Reply #3 on: 18 February 2013, 21:15 »
ah ok fair enough it was just a thought I had today as I know the rears are smaller. that's an easier way too!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 18 February 2013, 21:15 »
As above.  Just make sure the standard equipment is in good working order and stick some decent pads on there .
« Reply #5 on: 18 February 2013, 21:17 »
maybe ill do it and just reverse everywhere to make it worthwhile  :laugh:
Offline Screech16v
  • MK3 20vt AGU
« Reply #6 on: 18 February 2013, 21:20 »
Youre nuts  :grin:
« Reply #7 on: 18 February 2013, 21:27 »
some would say it's a backwards step.. ok ill stop now  :grin:
Offline Screech16v
  • MK3 20vt AGU
« Reply #8 on: 18 February 2013, 21:30 »
Maybe a touch of reverse psychology is needed here
Offline AGGGTi
« Reply #9 on: 18 February 2013, 21:38 »
Ive got some bendix pads on brembo disks on the rear, just as good as standard oem stuff. Id concerntrate on the front as mentioned. Im gunna go with tarox disks and mintex pads when i do my fronts, pricey though :sad:. Just make sure everything is working as it should, then your on to a winner!
