Author Topic: AGU over fueling and maf readings ???  (Read 3947 times)
Offline Dave-iow
« on: 18 February 2013, 19:52 »
evening all MK2 is running a little to rich for my liking. So looking for info on what the maf readings should be and or common problems that cause over fuelling.
1st off will try and get a maf to try see if its that! But what else..
Its an AGU Lump, with stage 1ish map, 2.5 Downpipe, all pipe work 2.5, induction filter, forge valve, front mount etc
So any ideas on what the MAF readings should be so we can see whats what
Dave :undecided:
Offline Chris.
Re: AGU over fueling and maf readings ???
« Reply #1 on: 18 February 2013, 20:02 »
in region of 150g/s id say?
Click For Build Thread
Offline Dave-iow
« Reply #2 on: 18 February 2013, 20:17 »
cheers, will do some runs tomorrow and log to see whats going on.
Hopefully Wazzer has a spare maf for me to try as well ;)
Offline Chris.
« Reply #3 on: 18 February 2013, 20:22 »
Log MAF 002, n75 025 and there's a lambda voltage in the 30s somewhere you can make AFR graph up from
Offline Dave-iow
« Reply #4 on: 18 February 2013, 20:23 »
Top man.
Hope this all makes sense to my man who can lol
Offline Chris.
« Reply #5 on: 18 February 2013, 20:56 »
Haha, simple enough.
3rd gear, about 1200rpm area, and floor it and hit redline at full throttle.
Post results up here and ill cast a eye over them see if i can see anything.
A over-reading MAF can throw fuelling out.  Is it a NEW genuine unit?  Even replacement parts have been known to be out.
Offline Dave-iow
« Reply #6 on: 18 February 2013, 21:41 »
Maf is what came with the donor car for my mk2 conversion. Will spec order a new one for weds as well
Offline Dave-iow
« Reply #7 on: 19 February 2013, 14:33 »
Right well got some readings today. Max was 130 g/s but was all over the place.
Does the Activated charcoal filter solenoid / acf/ N80 valve need to be plugged in or need a resistor fitting (bearing in mind this engine is in a mk2) to make the ecu adapt the fuel trims.
Suspect the car is not adapting fuel trims as it was showing an error in VCDS and might explain why the car is running rich?! !?
Any help would be great :(
Dave
Offline Dave-iow
« Reply #8 on: 19 February 2013, 15:01 »
seems i might need to dom sotnhing along these lines;
http://www.golfgtiforum.co.uk/index.php?topic=222678.0
Offline Chris.
« Reply #9 on: 19 February 2013, 18:33 »
162bhp roughly.
I dont think the charcoal canister plays any direct play in fuel trims.
Have you got the log to hand?
