Author Topic: Jacking point  (Read 4403 times)
Offline mrsaunders
Re: Jacking point
« Reply #10 on: 19 February 2013, 11:10 »
I generally use the rear subframe bolt mounting points on either side. Nice and solid.
This, my jack cup fits in perfectly
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Jacking point
« Reply #11 on: 19 February 2013, 11:25 »
I concur. :afro:
Offline Len
Re: Jacking point
« Reply #12 on: 19 February 2013, 12:45 »
I use the standard scissor jack on the sills until I can get my trolley jack under.
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
Re: Jacking point
« Reply #13 on: 20 February 2013, 17:59 »
Ditto Len - doesn't damage the sills then.  :smiley:
I lift on the scissor jack and use a trolley jack with some wood to pad it, to hold the car up on the subframe until axel stands are in position (i.e. scissor jack removed).
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Jacking point
« Reply #14 on: 21 February 2013, 14:10 »
The problem with the scissor jack as it disturbs the sealer on the edges of the sills and and allows corrosion to start.
VW BUSH
Re: Jacking point
« Reply #15 on: 22 February 2013, 20:31 »
And fcks it royally if it slips off.
Offline whileoceanasleeps
  • patience comes to those who wait.
Re: Jacking point
« Reply #16 on: 22 February 2013, 21:05 »
and it's even worse when your driveway is stoney gravel!
Offline John W
Re: Jacking point
« Reply #17 on: 23 February 2013, 18:01 »
Thanks guys for the advice!  :cool:
Kind regards
John
1997 VW Golf GTI 8V 5 door
1979 Porsche 924 Lux
1982 Porsche 924 Lux Auto
1986 Porsche 944 Lux
1996 BMW 525iX SE Touring (4x4)
