Author Topic: radiator fans  (Read 1004 times)
Offline dstv
radiator fans
« on: 17 February 2013, 18:26 »
Hi guys
I have asked this before but had no luck. my radiator fans kick in for no reason and runs for about 2=3 min then stops. I turned the ignition key today and turned it off and the fans just started running...thats without even starting the car. I had it with the mechanic last week who checked it for a hour with vagcom plugged in and everything temp. wise gos up as normal then cools down as normal. he said it could be my ecu as everything else seems to be ok...could my ecu be the problem here
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline EsSeX dAn
Re: radiator fans
« Reply #1 on: 17 February 2013, 19:43 »
is the air con on? if so turn it off and see what happens with the fans as they run when it is turned on. next thing will be the fan control unit has started going a bit wild. also is there enough water in the car?
i think i love you.....
Offline dstv
Re: radiator fans
« Reply #2 on: 17 February 2013, 20:12 »
the aircon is always off....I have never even used it since I bought it.. I will check the water in the morning...i have not checked that,...thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: radiator fans
« Reply #3 on: 18 February 2013, 09:13 »
Climate or air con?
Offline dstv
Re: radiator fans
« Reply #4 on: 18 February 2013, 09:28 »
Aircon....but like i said I turned the key without starting the car and the fan kicked in...so would the
aircon or not having water in the car cause it to run
