General discussion
Any plumbers on here?
4
5
Topic: Any plumbers on here? (Read 5241 times)
dom
10k hero
Back in a Mk4
Re: Any plumbers on here?
Reply #40 on:
18 February 2013, 12:42 »
Right then, removed the valve and sure enough water was flowing freely.
There is a check valve between the thumb and screw valves which appears to have broken. Problem solved, many thanks to those who contributed
dixie180
Here all the time
Mk3 8v Gti,Mystic Blue the best colour.
Reply #41 on:
18 February 2013, 16:55 »
Well done m8,them valves can be a bit of a pain.
bobbarley
Serious forum addict
I'm kind of a big deal...
Reply #42 on:
18 February 2013, 18:02 »
On another note. The garden tap kits, where you get a connector that splices into your existing cold water supply. Are they actually safe/any good?
dixie180
Here all the time
Reply #43 on:
18 February 2013, 18:06 »
Yeah perfectly safe,i have used them to fit outside taps for people on numerous occassions.Be careful if cutting into the cold water supply with it turned on tho.
Toby
Car - less
Reply #44 on:
18 February 2013, 18:19 »
I'd rather not use them tbh! I allways do mine with solderd copper! And the little things u screw on to the pipe if never trust!
Parsons Performance
R-Tech
Currently down under
dixie180
Here all the time
Reply #45 on:
18 February 2013, 18:24 »
Yeah each to their own.Could also cut the copper cold feed supply and put a T connector in but try explaining that to someone that may not have the know how.
Toby
Car - less
Reply #46 on:
18 February 2013, 18:42 »
It all comes down to how much they want to pay!
The amount of jobs that I go to which " looks simple enough" for the customer to attempt them selfs, ends up costing them more! Lol
Parsons Performance
R-Tech
bobbarley
Reply #47 on:
18 February 2013, 18:55 »
Aye, I'm not cutting up and soldering pipes myself, I don't have the tools. Am considering screwing a T joint where the washing machine pipe connects. Washing machine one side, external tap on the other.
dixie180
Here all the time
Reply #48 on:
18 February 2013, 19:39 »
Using a T joint would be okay as long as you don't use the outside tap at the same time as the washing machine.
Yep Toby i hear where your coming from,have experienced the same myself.
4
5
General discussion
